Pri/Sec. piping
Weezbo
Weezbo Member Posts: 6,231
it could look like lT TT -.-T -.--`- it all works mostly you are going for the placement of your pump and Expansion tank and air purger and fill piping and keeping it looking good :) :)
do you remember the left hand rule and right hand rule described by your thumb and forefinger and middle finger ? to make like X Y Z Axis intersections ? well by pointing both fore fingers together you can basically describe any direction off of a line. perpendicular to that line. air elimination is also a consideration like i said earlier so while some directions are all good and all, consider air elimination ...
you can turn the piping to all run on the same dimension or sometimes spining one t down and one t on the "flat works pretty good too :)
  • Joe Glinski
    Joe Glinski Member Posts: 4
    pri./sec.piping
    Hi i was wondering about pri./sec. piping does it matter were you pick up the sec. piping? On the bottom,side,or off the top of the pri. piping as long as the tee's are spaced 6" apart.Thanks For You Help Joe
