PE Pipe
L'town radiant
L'town radiant Member Posts: 36
Does anyone know of a manufacturer of polyethelene pipe fittings (PE, not PEX)?
  • Chris_82
    Chris_82 Member Posts: 321
    There are a number of manuf,...
    Plastic pipe and supply of woburn MA is just one example, why? You are getting into a specialty area, that generally needs specialty tools and training?
  • L'town radiant
    What I actually need are some 1 x 1/2 saddle tee's....think they exist in that small of a size?
  • bert
    bert Member Posts: 50
    one possibility
    Dawn Kwikseal makes them for PE irrigation systems, if
    you need 1/2" threaded outlets. No special tools req'd.
  • Chris_82
    Water Works supply or Plastic Pipe and Supply both in MA, RI and CT have irrigation and water supply barbed compression, or the more expensive push in types of fittings they can both order din, sae and various other sizes of exactly what your looking for.
