PE Pipe
L'town radiant
Member Posts: 36
Does anyone know of a manufacturer of polyethelene pipe fittings (PE, not PEX)?
There are a number of manuf,...
Plastic pipe and supply of woburn MA is just one example, why? You are getting into a specialty area, that generally needs specialty tools and training?0 -
What I actually need are some 1 x 1/2 saddle tee's....think they exist in that small of a size?0 -
one possibility
Dawn Kwikseal makes them for PE irrigation systems, if
you need 1/2" threaded outlets. No special tools req'd.0 -
Water Works supply or Plastic Pipe and Supply both in MA, RI and CT have irrigation and water supply barbed compression, or the more expensive push in types of fittings they can both order din, sae and various other sizes of exactly what your looking for.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
