Zone Valve
Can Zone valves be installed vertically?
Which brand of mechanical valve is more reliable Taco gold series or Honeywell V8043 F 1036? I have a radiant system that I want to put a zone valve on. My manifold is vertical. So I would like to know which would be the best way to go.
Thanks
Wood heat guy.
  • John Abbott
    John Abbott Member Posts: 361
    Taco.......
    is by far the most reliable and simple I have found in 35 years in the trade.it can be installed verticaly.
  • Pex Runner
    Pex Runner Member Posts: 4
    zone valve
    We usually use the callefi z one zone valve which is directional but can be installed vertically and horizontally. Taco esp series are pretty good also. We also usually install it on the opposite side of the circulator.
  • william_5
    william_5 Member Posts: 62
    yes any new manifolds i make up that is new boilers ball vale on supply after lwco 007 vone vale or vales than ball vales on top bad 007 or zone vale lock up the two ball vales replace what you have to in and out with little bleeding also you are working standing up not bending over a dryer been doing this since 1982 installed vertically with no trouble
