Snake for Pex?
m dewolfe
m dewolfe Member Posts: 92
Ok jim go out and get a cheap wire feed welder handpiece and use it in the manual mode to force a small wire down thru the pex. You can push that wire a long way sometimes as much as 200 feet then see where she stops measure the length of the wire and cut away. I have used a tone generator and a tracer and found a crushed piece of pex in a concrete floor. Worked well for me but I think there was some luck involved too good luck
  • Jim Franklin_2
    Jim Franklin_2 Member Posts: 70
    Argh!
    Putting the 4 zones of pex (runners to baseboards) onto the new boiler piping today. A few of the cardbord zone identifiers had fallen off the pex so I blew into the supplies to find the returns and got a nasty surprise. One run is blocked and passing no air, from either end. I have no idea how this happened. Anyone who's worked with the stuff knows it's way too stiff to be wedged behind a piece of sheetrock. It's 3/4 so I would have felt a kink.
    I'm going to try pumping it up a bit with the compressor, but I'm at a loss as to how I'm going to find the blockage. Any ideas that prevent me from hacking open walls and splitting runs in two would be greatly appreciated...
    jim
  • Weezbo
    Weezbo Member Posts: 6,231
    how about 150' of....
    1/4" plastic break hose, sharpened a bit on one end ,....slide that into 1/2" or whatever run some hot antifreeze through it,....then if it is and ice block,....it will melt its way through .
    hook a hose connection to the other end of it lash it up to your Wayne pump....run the pex into the fill bucket.as a thought.....?
  • jeff_51
    jeff_51 Member Posts: 545
    could try a fish tape?
  • Jim Franklin_2
    Great ideas...
    ...well, except for the water one :-)
    I managed to get a resonably tight seal on a manual air chuck and let 'er have about 40 PSI. POP! But the other line was still clogged. Now I'm picturing a coupler that never had it's center drilled out and I've just popped off one side, and other crazy stuff. Then I decide to stop being so stubborn and MAYBE the circuits don't go where they're labelled. Sure enough, I was wr-, wr-, mistaken, and popped the cap off the kitchen toe kick heater hose.
    Guess I get to re-label all the zones now. That'll teach me to work after 5....
    Thanks for the ideas, I'll file them away for the next guy ;-)
    jim
  • Weezbo
    what ? no likey idea?
    sheesh. mighta been frozen :) Th...hen you likey idea.
  • Jim Franklin_2
    Frozen?
    It's a new install. There's nothing in it but air. If that's frozen, I have worse problems than clogged pex :-)
    jim
  • Weezbo
    if a guy in 23 below might have a momment to splain*~/:)
    it is downright chilly around here :) if you take the caps off of pex that run between floors a convection current ensues,...if the temps are up while people are working and down when they leave this causes condensation within the lines, now i know thats a strech buh trust me. it could happen :)
