Any Jet-Pump Testers Out There?
Empire_2
Member Posts: 2,340
Look at it this way,....If it's an expense or costs you money, you have to charge for it! Just make sure when you explain it the you are passionate about YOUR better service and make the customer feel good that you are taking care of them and that's why the additional expense. Now, if you loose a job over it, then you have to re evaluate the increase for that person.......
Mike T.
Mike T.
I test jet or subs
on my bench,,I have the proper gauges(electrical and flow),and tank hook-up, but I`m getting tired of removing their usual IP stuff so I can run-it, sometimes I need the 3Ftr, or heat them,, thinking of charging extra, or is this a bad idea?
Dave0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
- 52 Industry Classes
