Black Stove Pipe for a Flue
Bruce M.
Bruce M. Member Posts: 143
Has anyone tried using black stove pipe for a flue? I believe it has a higher temperature rating than galvanized.
  • H. Green
    H. Green Member Posts: 22
    Black Pipe
    Temperature is not your issue for fossil fuel vent connectors, corrosion is. Black Pipe has virtually no corrosion resistance. You would be lucky to get a single heating season in a typical basement installation. Don't do it.
