what is the best residential steam boiler?
Jamie_6
Member Posts: 710
I would not be nearly as worried about the type of steam boiler as I would be worried about the type of steam boiler instillation.
I would like to know some opinions on the best built residential steam boilers, please.0 -
Anthony-
Everybody has their own opinion as far as best goes. In my experience, it ususally depends on the supplier, and how well they treat the contractor. I tend to use Weil or Burnham, but in my neck of the woods, that's because my suppliers that rep them are stand-up folks, and if I have warranty issues, I DON'T HAVE warranty issues-if you get what I'm saying. Most of the residential gas boilers I've seen are pretty much the same. I think the most important thing is how it's piped once it's in the boiler room-that makes all the difference in the world.0 -
when i had mine replaced all the plumbers that came over for an estimate 5 total , everyone single one said WM or Burnham. I went with the WM.0 -
Just my opinion...
Everyone has an opinion. Mine are:
Burnham's are well made and fantastically easy to clean if you plan on servicing it yourself. It's a real plumber's boiler. There have been some concerns of others about their quality slipping and they are fefinately cutting corners these days, but they are still my favorite. Nice people there, too.
Dunkirk makes a quality casting, well engineered boiler at a slightly lower price. I own several and will swear by their quality though they take half a day to disassemble and clean.
I wouldn't think of buying a boiler without iron nipples between the sections. Most manufacturers use a type of rubber stuff instead.
Long Beach Ed0 -
boiler
I had a Burnham installed 3 years ago. And I couldn't be happier with it. Just my opinion though.0 -
steam boiler
take a look at this v78,10 years old.....i'll take my chances with wm and those rubber gaskets.0 -
What happened?
Okay, dc, gotta tell us what happened to that thing?
Ed0 -
Jamie's right,drop headers,vented mains and radators. b4 to look @ a boiler get Dan;s book "Got steam heat" its a must for every HO looking to replace that old steamer.And finding the right person th install it.0 -
Peerless, You cant kill them with a tank.0
