why do gas furnaces use delay off blowers during cooling mode
Rookie_5
Member Posts: 6
thanks
To get additional cooling
If you stop the blower & condenser both at the same time you will be leaving the A coil well below the dew point. If you run it for a minute long you squise out some additional cooling.0
- 62 Biomass
