Gravity Wave
Paul Rohrs_4
Paul Rohrs_4 Member Posts: 466
http://www.flixxy.com/meteorology-gravity-wave.htm
Gravity Wave.....
Regards,
PR
  • Tombig_2
    Tombig_2 Member Posts: 231
    Cool!
    Since the whole sequence took 35 minutes it would be easy to miss in real time. I'm a sky watcher from way back and I've never heard or seen so don't feel like the lone ranger Paul.
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Not much difference between "gravity waves" and the things I observe and attempt to explain in a directly connected hydronic heating system served by a Vitodens with its radiant burner and variable speed circulator.
    If you "push it" I even see some similarities to "Gravitational Waves" when I attempt to understand the radiant interaction between the boiler, the emitters and ultimately the shell containing those emitters as affected by the sun.
    By definition, "discoveries" come from the unknown and/or unobserved...
