Room Temp way higher than Thermostat setting
Timco
Timco Member Posts: 3,040
How many pumps do you have? If you have just one pump, and two zone valves, it sounds like a zone valve is stuck open and continuing to call for heat.
T
Just a guy running some pipes.
  • Mike Cohen
    Mike Cohen Member Posts: 1
    Room temp way higher than Thermostat setting
    Have forced hot water from Oil burner, with 2 stages (upstairs and downstairs). This problem just started about 4 days ago: Bedroom thermostat set to 65 at night, but heat stays on, and it gets above 80 until I turn off the Burner. Thought it might be the thermostat, so I switched the upstairs one with the downstairs one. Bedroom still getting too warm. Is there a control at the burner that might be bad, or could it be bad circulation w/in the upstairs loop?
  • Wayco Wayne_2
    Wayco Wayne_2 Member Posts: 2,479
    Oh yah
    it sounds like gravity circulation. A zone valve or flow control valve are likely culprits if you have one. Hot water wants to rise. If the downstairs zone is heating and there is a path for hot water to rise on it's own, it will do just that. Go downstairs and grab the pipes and think like hot water. Where would you go if you could. (Paris mayby?) (Sorry ignore my drift) :P WW
