Waste oil heaters
Ken D.
Member Posts: 836
Does anyone know who manufacturers waste oil heaters and where to buy in the Philadelphia area? I have had no luck through normal PHVACR suppliers. Also, are there any problems with them and are they worth the effort? Thank you for any information.
Waste Oil Heat
The two I know of are Clean Burn and Black Gold, mostly it is cleaning them often but concidering what you putting in thats not all bad
http://www.cleanburn.com/
http://www.energylogic.com/
http://www.wasteoilboiler.net/waste_oil_product_lines.html0 -
waste oil boilers
www.columbiaboiler.com0 -
waste oil
There is also an outfit called Lanair.com I think renzor also makes those things.
I am away from the office until 1-27. I think we have worked on several other brands.
Waste oil units need clean and service atleast twice a year.
The products left after combustion can be extremely dangerous to the sevrice persons health. You should invest in quality vacuam and protective gear. That gear will be need often.
Mike0 -
Reznor
makes a waste oil heater right there in PA somewhere.0 -
Thank You.
Thanks to all.0
- 120 Geothermal
- 396 Solar
