Outside Design Temperatures
Brad White_71
Member Posts: 11
Richard-
See the attached in PDF format. USAF data, 18 pages with lots of good stuff. First page is a good summary.
I would use the 99% or 99.6% values for heating and the 1% values for cooling, but you know the area, you be the judge.
Hope this helps.
Brad
Hope this helps.
Brad
Outside design temperatures
I am trying to find the o.d.t. for N. Massapequa/South Farmingdale area. Can anyone direct me to where I can find this information. Thanks.0 -
what state?
Canada? Mich? Maine? Texas? Az?0 -
Design Temps
That would be for Long Island N.Y.0 -
O.D.T.
Sorry - Long Island N.Y.0 -
Check your e-mail
You should have a response e-mail from me on 5/12 @ 8:47 AM with your answer.
The temps were:
15 degrees heating
About 87 degrees cooling
Regards,
The Professor
"http://www.crownboiler.com/educate/heatloss.asp"
keep scrolling down and there is a list of cities and temperatures.0 -
O.D.T.
Thank you - I have read your email, however my town borders Suffolk county not Queens county. I checked the crown boiler website and the best I can find is 10*. There doesn't appear to be much difference between Queens and Nassau county temps. I was trying to get as close as possible to my town. Thanks again.0 -
O.D.T.
Thank you.0 -
Design Temp
What is what is the coldest outdoor temperature at which you want the system to maintain your target indoor temperature?
-Andrew0 -
You are taking the numbers too seriously. A few degrees should not matter, there is enough slop in the system that if it works at 10F it should work at 5F. Heat calc programs leave a generous safety margin.
Of course, there can be exceptional cold waves where the heating system won't be able to keep up, but if it is 5F colder than what the heating system can handle, it will take a day or so of the cold wave before people can feel that the house is getting cold. And such extreme cold usually doesn't last very long.0
- 167 Indoor-Air Quality
