heat loss
shawn_5
Member Posts: 52
I went to a job today that had a room that was 23 x 16 the ceiling height was at the highest point 14 ft.high the lowest was 8 ft. high it was like a triangle.now the room had at the top a big triangular window 19 ft long and the highest po0int is 6 ft. high also the room had 3 sliders each is 9 ft long by 6 ft. high.right know they have about 12 ft of baseboard and 2 electric wall heaters I do not have the heat loss software anymore I just ordered the slant fin one again I know radiant sounds perfect for this application.there is not enough wall space for baseboard.three out of four of the walls are outside walls .I would like to know if anybody could do a heat loss.or has any ideas.thank you
Tough call
Where's the house - Texas or up here in the Great White North? What's the wall construction - 2x4, 2x6, concrete? How many walls are external?
There's a lot of info required before this questions gets answered.0
