Cast Iron baseboard Rads push nipple removal
Dan C.
Dan C. Member Posts: 248
Doesn't take long . Just heat up the nipple and pull it out. I think thats the only way.
  • Jim Dawson
    Jim Dawson Member Posts: 6
    Cast Iron Baseboard Rad push nipple removal
    Does anyone know of a tool or faster way of removing the push nipples from the cast rads besides heating up the rad with a torch and grabbing with a vise grips. I'm trying to refit some rads together but the existing rads have either one or two nipples installed in same spot as the rads I'm fitting in.
    I was hopping not to trash them or replacing them.
    Thanks
  • mike yozell
    mike yozell Member Posts: 7
    push nipple removal
    if you need to do a lot of them than go to an autobody parts store and purchase a "slide hammer " you can make a hook for the end and out pops the nipple
    mike
