Key Indicator
The link posted by Mike is a good one but you can only a buy allot of them. It would cost about $500.00 US for a small order. You could call Viessman as they give them away or maybe a friend on the "wall" could hook you up! John
  • Darin(in Michigan)
    Darin(in Michigan) Member Posts: 90
    Key Indicator
    Does anyone know what the part number for a Grundfos key Indicator is. I would like to order one but have no info on them.
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Here's a link to the manufacturer but I'm unable to find actual retail sources.
    You might try a letter or call to Grundfos USA: Grundfos Pumps Corporation U.S.A.; 17100 W. 118th Terrace; Olathe, KS 66061
    Phone: (913) 227-3400 - Fax: (913) 227-3500
    No Speak Swede!!
    I can't thank you guys enough. Who'd of thought something so complicated(be honest, they can be) as verifying pump rotation could be troubleshot with something so small. My only regret is not knowing they existed earlier. I can only imagine the puzzled look of our field reps if I asked about them. I'll try Viessman first and go from there. Thanks again.
