How to get my suction pressure from vacuum
Empire_2
Member Posts: 2,340
More info would help as in what type of ststem are you working on, TXV or cap, filter dryers? etc...
Mike T .
Mike T .
Ean Wrightson needs help on this one. I did a compressor change out. Upon turning on the unit everything works but my suction pressure drops into vacumm.0 -
ck
LL valve open filter dryer LLine open meatering device closed .Think about how the flow goes through sys. something is stopping it . How bout the rubber plugs in the compressor ? where they removed ?0 -
LOW PRESS---VAC
Morning All, Ean,is this AC? Refrig ?Freezer?Cap tube ?TXV?
Maybe ,now you have the symptons of what killed the old compressor. How old was the compressor you replaced?0 -
Definitely in Need....
... of more information...
How much refrigerant was recovered from the system?
How much refrigerant went back into the system?
Is the new compressor an exact replacement for the old?
Different compressors have different internal volumes, which ultimately affects the final refrigerant charge in the system.
You need to take operating temperatures, pressures and calculate superheat and subcooling to see what's going on.
Gather the following and let us have another look:
System refrigerant:
Size/model/etc:
Outside ambient temperature:
Condenser saturation temperature:
Condenser outlet temperature:
Evaporator saturation temperature:
Evaporator outlet temperature:
Return air temperature:
Supply air temperature:
Temperature of the suction line near the inlet of the compressor:0 -
Eugene,....
On that E-Mail I sent you,..If I could draw like that, I wouldn't have to do HVAC for a living;-) Very 3 D like dont ya think?
See Ya
Mike T.0 -
Nothing short of....
AMAZING!0
