Did It Again
RonL
Member Posts: 13
Well. Got up this morning, put on the kettle, sat down at the computer, and started researching. Did heat loss analysis. Jumped from site to site checking figures. Took notes and did calculations. Finally, I sat back and reached for my coffee. ?????? Went into the kitchen and found that I had boiled the kettle dry again! Steam heat of sorts. Gonna install a LWCO on the kettle before I burn down my yurt.
I have done it before.
Getting into my work and everything alse goes by the way side. Instead of a LWCO, try an automatic fill pump to keep the water at desired levels.......:)0 -
two words
Mr. Coffee0 -
Thanks RonL
That just made my day, i almost fell off my chair Thanks...David0 -
Coffee
Hey Ron,
Everything happens for a reason. Maybe it was for the best.
About a year ago someone posted here with a link to a site for a commercial. They said look for a ghost in the video.
I had just sat down and I DID have my VERY LARGE cup of piping hot coffee. I played the video with the volume up loud.
When the ghoulish creature appeared in the video and screamed, I did not spill all of the coffee directly on my crotch, only half of it. The other half spilled on my keyboard.
Hey, "Feces Occurs",
Ed Carey
- 120 Geothermal
