Wiring diagaram for indirect
Dan_40
Member Posts: 15
Thank you John I really aapreciate it. It would be nice if the electrical contractors we use would be up on the finer things in life. I appreciate the diagram as well as the quick response. Thank You
Wiring schematic for indirect off a steam boiler.
Does anyone have or know where I could find a suggested wiring schematic for a superstore indirect piped off a steam boiler. In the past, when my electrician has wired the relay. Pump/burner would shut off at high limit setpoint. I understand that burner should shut off but I want circ to run until aquastat on indirect is satisfied. Any help or direction would be greatly appreciated.
Thanks
Dan0 -
Here:
The aquastat can be in an immersion well on the boiler or on the loop piping. (However you have it set up)
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Electrical contractors HATE low voltage.
I have no idea why, but they do.
I make these simple little diagrams and give them to my guys.
Sometimes you just gotta make your own electricians.
Classes0 -
- 167 Indoor-Air Quality
