Taco mixing valves
kevin coppinger_4
Member Posts: 2,124
but depending on the boiler and the load for each radiant zone boiler shocke could be an issue....what temp is each running on? kpc
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Taco mixing valves
Can anyone tell me if it is ok to use taco 5000 series mixing valves in this position to run 2 zones of radiant heat. Taco diagrams don't show them in this position and would like to know if this arrangement will work before I pipe them in. Thank you Tom.0 -
Taco mixing valves
Can anyone tell me if it is ok to use taco 5000 series mixing valves in this position to run 2 zones of radiant heat. Taco diagrams don't show them in this position and would like to know if this arrangement will work before I pipe them in. I have 3 baseboard zones existing now. Thank you Tom.0 -
Thats exactly how we do them, no problems ....so far.0 -
Kevin, boiler is a Quantum 90-200. Thermal shock is not an issue. Taco only shows a diagram of primary/secondary injection loop and how they want a thermal trap to prevent unwanted heat transfer into the secondary loop. Just was not sure if it was ok to pipe this way. Thanks for the info. Tom0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 985 Plumbing
- 389 Solar
