SS Chimney liner
joel_19
Member Posts: 933
Any supply house your buying the boilers from will have or be able to get you a liner.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=254&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Stainless chimney liner
I'm looking for an 8" x 50' stainless steel chimney liner.....anyone know a source in the northeast........thanks in advance0 -
Elmer's Pipe
Hi Mike,
I've used this product before. They can custom roll up to 12" diameter. 50' shouldn't be a problem for them to make, but it will be pretty exciting to install. (Think Heavy)
http://www.elmerspipe.com
Paul B0 -
Just a question
What are you venting? 8" is pretty large. You might be able to downsize.0 -
Liner
I'm venting two Viessmann vitogas boilers..........sizing is correct, I'm looking for a flexible liner........0 -
Liner
We use Z Flex with no problems. I'm sure they have a supplier near you.0 -
50 Feet?
I'd be a little concerned with condensing the chimmney in this application. Are you doing boiler reset in this application? What stack temps do you expect to have?0 -
liners
I recommend you contact a local relining pro. They can assist you with the sizing, choice of alloy, brand, warranty, termination cap, and installation. An 8" is huge, esp. for such efficient equipment. Also, you may want to insulate this liner to minimize condensation. Probably will want AL 29-4C alloy instead of 316Ti. Type 321 is garbage and doesn't hold up. It is better suited for jet engine nozzles.0
- 50 Industry Classes
