Defective gas valve?
David Hohengasser
Member Posts: 52
I have a Honeywell Model# V800A 1310 gas valve on a steam boiler. It is original equipment on a 1987 HB Smith boiler. I had the natural gas off at the main to change some unrelated piping, so the pilot was out. A call for heat was made, the damper opened and the I heard the click of the solenoid opening the valve. So I just checked this with the gas back on. The pilot is out. The call for heat is made and the valve opens and fills the tubes with gas and the pilot is out. I thought when the pilot was out, that the valve could not open. Do I have a defective valve or could it be wired incorrectly?
Gas Valve
You need a Pro in there immediately.
Someone who has experience servicing gas systems.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"There was an error rendering this rich post.
YES YES YES
The valve is defective. Turn off the gas valve on the pipe leading to the boiler NOW. Get the valve replaced. That valve should never open under those conditions.0 -
Valve is off
Thank you. Valve is off. I will have it replaced first thing tomorrow morning0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 986 Plumbing
- 389 Solar
