Best styrofoam cutting method.......(Starch)
...I appreciate your feedback.
I have always used the "score and snap" method. Was wondering if anyone had come up with a better way for custom cuts. I'm going to check on the hot knife thingy!!
Starch
  • John Starcher_4
    John Starcher_4 Member Posts: 794
    I'm just curious.....
    ....as to how you all do it? Specifically 2" blue board.
    Do you use a utility knife?
    Starch
  • Boiler Guy
    Boiler Guy Member Posts: 585
    Makita 7.2 volt jig saw
    slick , light and accurate
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    Yes, utility knife or segmented snap-blade knife
    and a straight-edge. Cut as deep as the blade will go. If not all the way through but most of the way, snap it across a hard edge like a 2x4. It should break cleanly.
    If you are installing one layer, seal the gaps with low-volume spray foam and cover with heavy foil tape. If doing two layers, seal the joints too and lap the second layer with staggered joints. Seal gaps accordingly for a nice tight finish.
    Cover with GWB as local codes require, for a fire barrier.
  • Chris E
    Chris E Member Posts: 11
    cutting foam
    There are 2 good methods to cut foam. One would be using an electric carving knife. The other is one that I made with an electronics soldering iron attached to an old bread knife. Here is a good website.
    http://wolfstone.halloweenhost.com/HalloweenTech/fotmak_MakingFoamTools.html
  • Chris E
    another website
    Here is another website you can try.
    www.hotwirefoamfactory.com
  • hr
    hr Member Posts: 6,106
    On the job
    I use a Short Cut hand saw from Stanley, or the knife and snap method.
    The saw works better if you have to notch or cut holes for pipe, etc. Straight lengths thru the sheet works fine with the knife cut.
    For a nice straight cut, pile one sheet on top of the other for a knife guide.
    Saw cuts do make a mess of foam dust :) I have used my table saw to cut 45 bevels for the edge insulation detail. Now that's a real mess maker :)
    hot rod
  • Dennis
    Dennis Member Posts: 124
    Sawzall and a vaccuum, is the quick way.
    The vaccuum is so I can say there is no mess.
  • Heatmeister_2
    Heatmeister_2 Member Posts: 88
    Sheet rock saw
    BUT my neighbor swears by a thin long filet knife.
