cleaning recessed rads
JB_8
Member Posts: 85
You or the HO got to take it out drain it put a shop vac on the pipe going to the boiler and on the radiator and suck out the junk. Take a look in the valve to see if it was put on to tight and the return line is blocked by the pipe itself going up into the valve. Something is blocking the return of the water to the boiler. MY 2 cents
I know plenty of question from the clam today .Wwll here we go ,i did a look see at some ones job who posted here and besides from a not ideal near boiler piping which doesn,t surge or bang ,i check out a gurgling 2 nd rad ,the rad in question is a recessed rad and does make a type of water running sound the rad was not pitched which i told the HO but he insisted that when it was pitched that it made no difference .Has anyone ran into this promblem ?The only reason i can thing for the noise is cold back wall (brick home no wall insulation) and that the internal passes of the raditor has a build up of mud and cr*p in it and is holding water forming vacume pockets drawing the steam into the rad and quickly condensing this seems to happen on intinal start up and doesn't seem to happen after the rad is hot also HO is complain about the air vent noises he thinks it's to noisey ,he does have some gortons but he did have a few vari vents here and there the rad in question did have a vari vent which was not working i replaced with a gorton and she heated up and was making some running water type noises but after intinal heating up it disappeared .So if i an correct and there is a build up of debre in the rad what is thge best way to clean it since there is no access plug to the push nipple passes on the rad would removing the oppisite plug and maybe flush witha acid pump remove this garabe and possibly stop the promblem or should i just run away in closing this gentlemen has contacted others also i believe i'm the 3 or 4 guy and even though his near boiler piping is not close to being correct i believe he just wants the rad noise to dis appear including the ones that are venting correctly thanks for any input peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
a disaster
run like a thief, this guy deserves no help from you. you touch one thing and you are married to it.0 -
thanks Mr.young
I believe i may take that road i've been on a getting beat up thing recently and i think i may just tellem to call the last guy and just replace it with a new one i kinda have a feeling some one might have thought that operating the raditor with the valve slightly closed would give you less heat and may be the reason behind whati think is alot of garbage in the rad thanks peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
- 167 Indoor-Air Quality
