e.d.r. ratings
Brad White_9
Brad White_9 Member Posts: 2,440
I would take off the area of the tubing as you see it. Have to be pretty close... How accurate do you need it to be anyway? How modern is this? Runtal or is it newer but cast iron?
  • Heatman_2
    Heatman_2 Member Posts: 65
    e. d. r.
    where is a good source for panel rad e.d.r. ratings, I also came across a small bathroom rad, that had the square panels mounted perpendicular to the wall, exposing almost all of the main rad piping.It was a newer radiator, 12" tall, 6' long, and 1 1/2 deep. with 1/2 tubing. Help guys, gotta get this load calc and bid done so I can go to bed.
