I am told you cant smell CO
Bob Harper
Member Posts: 1,109
Please understand: you do NOT have to have aldehydes present to have CO!!!
You can have quantities of CO with no apparent aldehydes present. However, as previously pointed out, if you do have aldehydes then you know you have CO. However, is your nose calibrated to sense levels of CO?
HTH,
Bob
HTH,
Bob
So I am always told you cany smell CO, But what am I sencing or tasting when
The wife has the oven on with no exchaust fan
You start up a water heater on a cold flue and it spills for the first couple of secounds
You lean over and old hydro therm and the smell you get from the top of the unit.
Your standing out side buy a direct vent fireplace.
I smell smoke
While CO is odorless, it isn't the only by-product of combustion.
Aldehydes among other by-products do have odor.
When you're standing outside by a fire, you smell smoke yes?
Hope this helps.
Mark H
And
if you smell aldehydes- which smell similar to, but not quite the same as, raw natural gas as delivered to the house- you DEFINITELY have excessive CO. Have those applinaces tested and repaired.
maybe not, but I can always taste
the aldehydes which are present when co spills in to a space. Mad Dog
That is a true statement
CO is a colorless, odorless and tasteless gas. What you smell are the other combustion by products that are present in any flame, be it gas, oil, LP, woodor corn, etc. CO occurs at dangerous levels in any flame that is not operating under the correct fuel/air ratio.
If you smell flue gas in your house, you have something wrong. Period! Get it checked out.0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 970 Plumbing
- 386 Solar
