Solid state 110 relays
Mike T., Swampeast MO
Member Posts: 6,928
I've used a lot of solid state relays, but never for heating/cooling equipment. Some quirks that might cause problems:
1) Heat is their enemy and the larger the load, the more heat they produce--you need a good heat sink and good natural ventilation (forced ventilation if you pack a lot of them in a small area).
2) Pay careful attention to the load rating. Resistive loads aren't as bad as inductive loads but even with resistive loads give yourself at least 25% headroom in the load rating. A filament burning out in a lightbulb will frequently take out a closely sized solid state relay.
3) They're extremely reliable--I had one set of four that probably each switched 40-50 times per hour for 4-5 hours per day for over 10 years. When they fry due to excessive load they fail open. I did however have one fail closed for a reason I never understood--this alone may be a "killer".
4) You can only test them with a load connected. You can't just use an ohm meter.
5) They're available in a number of "coil" voltages--I've only used low voltage DC but believe I've seen them for 110VAC.
quiet ones
Hello i have installed a few electric boilers and have one that is right behind the master bedroom and have some noise problems. Is there a solid state relay that can be interchanged there to make it quieter?
Thanks
Mike.C0 -
Contactor
I never seen one but I am sure someone makes them...
Just a thought if you have no luck.... Can you move the contactor near the fuse box or out of the boiler room...Or did you try another one.0 -
mercury contactors
you may consider mercury contactors.
look for an industrial electrical supply house.
high power solid state will most likely be very costly.
heres one:
http://www.wolfautomation.com/Product.aspx?ProductID=804&gclid=CL_Qy6uKtosCFSBhgQodiQT8wg0 -
RIB
http://www.functionaldevices.com/ChartPilot.html
These are the quietest that I know of , and are available up to 30 amp. Most DIN mounted " ice cube " relays are quiet as well...but do not offer dual coil voltages. If I had to live with 1 relay type , it would be RIB. Also , the brand name " Core " makes nice relays and transformers.
http://www.lectrocomponents.com/0 -
SSR's
I've used thousands in 24/7 manufacturing application for heating... maybee changed out 100 or so . As Mike stated they don't like heat and voltage spikes (dead shorts) wipe them out.See PDF on Omrons.0
- 50 Industry Classes
