Another Gravity Conversion.
Steamhead (in transit)
Member Posts: 6,688
another line-sized circ that's oversized. How much EDR on this system?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
I guess,
at installation time the boiler temp gauges were pretty impressive looking, but with no system bypass method, adjusting the boilers ΔΤ was a mute point.
BTW- You oil this circ with a side-shot oil can.
Dave0 -
Thanks Frank,
I haven`t deciphered it all yet, but its capacity is 2437 @ 150 and it`ll fall quite short of that. At least there is no asbestos on this one! LOL.
Dave0 -
The new system circ
should be sized to the radiation, not the heat loss or boiler size. The system ΔT should then fall right into place. Go here for more:
http://www.heatinghelp.com/newsletter.cfm?Id=125
If the new boiler needs a certain flow rate or return temp protection, a primary-secondary setup will let you do these things while maintaining proper flow rate in the system.
But you know all that ;-)
- 167 Indoor-Air Quality
