Infrared Thermometers w/laser pointers
Daniel_3
Member Posts: 543
Try harborfreight.com
if you are looking to save a buck or two.
Infrared Thermometers with laser pointers
There do you get Infrared Thermometers with laser pointers. I am looking for a source of supply, ... who sells them? I have a lot of steam traps that I want to monitor/check for insert replacement. Am told that the barehand touching a trap dischage pipe is not the best way of judging a good vs bad trap. Traps are typically Barnes & Jones #122 & # 134. Bromley0 -
Infrared T-meter
Mine is a Yellow jacket made by Ritchie Model #69235. I purchased it at R.E. Michels Co. Any good HVAC supply house should sell them, Field piece makes one as well. Best Wishes J.Lockard0 -
FERGUSON
infra-red thermometer
The thing you need to watch is the 'spot to distance ratio'. If you are taking measurements from 20 - 50 ft. You need one with a good ratio to be accurate. (accuracy = $$)0 -
Ridgid also has a new model
available. Also check out the offerings at Johnstone Supply.
hot rod
I have
A Fluke 62 Mini..around $100 or so from Grainger0 -
ridgid
> Johnstone Supply.
> hot rod
> _A
> HREF="http://www.heatinghelp.com/getListed.cfm?id=
> 144&Step=30"_To Learn More About This
> "Find A Professional"_/A_
ridgid
the Ridgid is also available at Ferguson. Part number 23578, Ridgid #IR-100
http://www.ridgid.com/Tools/IR100-Thermometer/index.htm
might not be
the quality you're looking for, but sears has them... craftsman.0
- 120 Geothermal
