weil mclean info...
Ben_8
Ben_8 Member Posts: 1
I'm trying to find the input of a Weil mclean ,steam gas boiler.
It's an atmospheric boiler, working with natural gas.
20 burners on the left ,and 18 burners on the right!
It's a LG2 serie....but no name plate!
Impossible to clock the gas meter(too much equipment ...)
Thank's....
  • lchmb
    lchmb Member Posts: 2,997
    If
    If you have the dimension's of the boiler itself you can tell which model through the Weil Mclain website... Here is the link to the lgb 2 series... Good luck
    http://www.weil-mclain.com/FTP/LGB_Manuals/LGBbrochure.pdf
  • Robert O'Connor_12
    Robert O'Connor_12 Member Posts: 728
    Ben
    Can you give any more info? From what you are saying, it could be a couple of different ones. Based on your info, I'd guess it was either a LGB-22 or 23. The 22 is rated @66.1 HP and the 23 is @69.2 HP.
    LGB-22 is aprox. 2,730,000 in
    LGB-23 is aprox. 2,860,000 in.
    Robert O'Connor/NJ
