Radiant Ideas For The Pro's
Brandon_4
Member Posts: 17
HPS Controls in Canada manufactures a station that could do all this for you.
Visit www.hpscontrols.com for more info.
What does everyone think of these radiant ideas?
In Canada's national newspaper no less.
Radiant Heat/a<>0 -
Painting with broad strokes?
I guess I lost interest when the article describes a Geothermal Radiant System and then claims it can be done for the same cost as a Forced Air Ducted System. I will, of course, believe it when I see a complete breakdown of parts and labor.0 -
$500 for the tubing?? Must be a very small cottage.0 -
Is it me or
are some of the pipes crooked in these panels, as I looked at their website with the pictures of different panels it looked like every panel had some piping that was not level, plumb etc. If my men installed crooked piping I would make them replace it.
I liked the part
Where putting insulation up underneith a floor without plates creates the same heat output as floor with plates, except you have to turn the heat up slightly. It sounded like they were doing everythign right, until that point.
I feel sorry for the homeowner. I wonder how they are going to run radiant, in Canada, with geothermal, and no plates, and get sufficient heat.0
