How do ya?
S Ebels
S Ebels Member Posts: 2,322
Anyone know how to take a drawing done on Siggy's hydronic cad software and convert it to a JPG so I can send it to someone?
  • ALH_4
    ALH_4 Member Posts: 1,790
    Would pdf work?
    If you have the full version of Adobe Acrobat you can send them as pdf's.
    Also PDF995 is a free version that I use. When you choose print, it shows up as a printer in the list, same as Adobe.
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    You can always do a screen capture by pressing "Ctrl+Print Screen".
    This puts a screen imagine into the clipboard.
    Then go to any image editing software, select "new" and paste the screen image. You can then crop/edit however you like and save in .bmp or .jpg format.
