Valves like this?
gave me a box with these valves yesterday that are new, and I have no idea where a person would use them. I assume they are industrial HP, but I have never seen this configuration before. They are .50" & .75" IPS, any ideas? I`m just curious is all. <BR><BR>Dave
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Metering valves designed for precise flow regulation?
  • Thanks Mike
    I will say that the guys Father worked in a milk plant for years, maybe these had something to do with that?
    Dave
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,713
    Strahman (the name on the valve body)
    has a website, and they make a lot of sampling valves for industrial applications, but they don't show this one in their current offering.
    Retired and loving it.
  • Thanks Dan
    I looked there too, couldn`t find anything either. Maybe these things date the "horse & cart" days, who knows!
    Dave
  • bob_50
    bob_50 Member Posts: 306
    I know
    that they make some valves and a wand that you supply with water and steam. They are used for washing down equipment and the surroundings. I have piped them but all I know is you stick the pipe in the hole hold it straight and turn it to the right.
  • ed_25
    ed_25 Member Posts: 6
    valves
    i would use them for getting cash at the local scrap yard.
  • Glenn Sossin_2
    Glenn Sossin_2 Member Posts: 592
    Valves
    I agree. They look like the would be used for flow regulation. Similar to a plug valve Jenkins used to make. I can't remember that model number but found this spec which looks like what you have from Jenkins (Crane) website.
  • Glenn,
    I agree with you and Mike, and appreciate your link, Thanks, but these are a different configuration than a "conventional" globe valve. I would never have any use for them, I was just curious.
    Dave
