Valves like this?
gave me a box with these valves yesterday that are new, and I have no idea where a person would use them. I assume they are industrial HP, but I have never seen this configuration before. They are .50" & .75" IPS, any ideas? I`m just curious is all. <BR><BR>Dave
Metering valves designed for precise flow regulation?0 -
Thanks Mike
I will say that the guys Father worked in a milk plant for years, maybe these had something to do with that?
Dave0 -
Strahman (the name on the valve body)
has a website, and they make a lot of sampling valves for industrial applications, but they don't show this one in their current offering.Retired and loving it.0 -
Thanks Dan
I looked there too, couldn`t find anything either. Maybe these things date the "horse & cart" days, who knows!
Dave0 -
I know
that they make some valves and a wand that you supply with water and steam. They are used for washing down equipment and the surroundings. I have piped them but all I know is you stick the pipe in the hole hold it straight and turn it to the right.0 -
valves
i would use them for getting cash at the local scrap yard.0 -
Valves
I agree. They look like the would be used for flow regulation. Similar to a plug valve Jenkins used to make. I can't remember that model number but found this spec which looks like what you have from Jenkins (Crane) website.0 -
Glenn,
I agree with you and Mike, and appreciate your link, Thanks, but these are a different configuration than a "conventional" globe valve. I would never have any use for them, I was just curious.
Dave0
- 167 Indoor-Air Quality
