Wirsbo 501S Setpoint controller wiring
heatboy
heatboy Member Posts: 1,468
The control is powered with 24 volts then the end switch starts whatever it is you're running. The sensor also has it's own termainals which are clearly marked on the board.
hb
  • devo
    devo Member Posts: 20
    I recently picked up a Wirsbo 501S Setpoint controller and the unit didnt have a wiring diagram with it. Is anyone familar with the specific wiring of this unit? This is the first one of these I have ever installed.Any help would be appreciated!
  • John Barba_2
    John Barba_2 Member Posts: 92
    this should help...
  • devo
    Response to my original inquiry!
    Hello hb and John Barba! I would like to thank the 2 of you for responding to my inquiry about the Wirsbo 501s setpoint controller. Your help and time were greatly appreciated! devo
