steam boiler sub-basement pit URGENT
Robert O'Brien
Robert O'Brien Member Posts: 3,578
pay to see a hamster sing Bei Mir bist Du Schoen!
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=313&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
    ? Member Posts: 4
    I have this problem for homework due tomorrow and I can't find it anywhere. It asks "Why are boilers (steam boilers) sometimes located in a sub-basement pit?"
    Thanks!
  • jp_2
    jp_2 Member Posts: 1,935
    gravity?
  • Is this a school project
    or something you left until the LAST minute? Try the library here, you may find what your looking for.
    Dave
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    Heck of a school they are sending you to....
    The primary reason many older boilers were located in pits is to assure adequate "A" dimension, the dimension between the boiler normal waterline and the lowest steam carrying pipe.
    If the boiler was higher and the "A" dimension compressed to less than 28 inches (1 psi pressure), condensed steam (condensate or return) would not make it back to the boiler and hammering/banging would occur.
    All hell would break loose, dogs would mate with cats and hamsters would start singing show tunes in Yiddish.
    I made that last sentence up.
  • JimH
    JimH Member Posts: 89
    plagiarism test
    That last sentence will serve as a plagiarism test.
    -JimH
  • David Sutton_6
    David Sutton_6 Member Posts: 1,079
    Hmm things to think about
    Thu i found the first part very intresting ..i find myself seeking deep thoughts on the second, Dogs and cats hmmmm, but the hampster thing may keep me up at night.....
    David
  • Brad White_9
    Maybe Matt
    can spot you a couple of tabs or something from his locker and you can hear that for free...
  • Boilers in Pits
    The reason a boiler is installed in a Pit is due to the fact taht there is not enough height between the lost steam carrying pipe and the water level of the boiler.
    There is a measurement called Dimenson A. That measurement means that for boilers less than 100,000 BTUh a height of 14" must be between the bottom of the lowest steam carrying pipe and the boiler water line. Boilers greater than 100,000 BTUs require a Dimension A of 27".
    This thumb rule is predicated on this fact, Smaller boilers generally have a system pressure drop of 1/4 psi or less and larger boilers have a system pressure drop of a 1/2 psi.
    Small boilers have smaller pipe and shorter runs of pipe.
    Large boilers have largwer pipe and longer runs.
    The two different A dimensions are based on pipe and system resistance.
    Jake
  • big willy
    big willy Member Posts: 92
    pit
    The best thing about anything in a pit is when you have to make a repair and end up standing on your head and barking like chicken just to get to it.
    I do complain alot
