Bosch tankless water heater, problem
John_82
Member Posts: 63
a.o. smith 75 direct vent waterheater..... forgt theose wall hung-tankless pieces of snit....
Bosch tankless water heater, 125 ng
I just cleaned out the water regulator, removing it from the unit, and put it back in, cleaned it, put a new rod thingy in it, that did have some mineral build-up, now I have low flame and cool to warm water. I started the fix because of fluctuating water temp, now it is worse. Any suggestions, I am in Portland OR0 -
bosch
If they are like paloma, water flow rate/pressure affects firing rate.Something else plugged?
I will check further.0 -
bosch
Go to www.boschusa.com & follow the links to tech support.0
- 120 Geothermal
