#4 oil burners
vinnyd
vinnyd Member Posts: 1
anybody know were to find a small #4 oil burner firing at about 8-12 gph to retrofit on a kewannee type c 2751 firebox boiler in the new york area? the small ones are tough to find.
  • Jim_47
    Jim_47 Member Posts: 244
    Big Burners
    Vinny, Are you retrofitting or replacing? If I had a customer with an 8-12gph thirst of number 4 oil, I'd buy a new burner. Get with a supply house and buy a beckett carlin or riello. Somebody from one of those big 3 will be glad to help.
  • Ed N.Y.C.
    Ed N.Y.C. Member Posts: 73
    Why would you
    Want to install # 4 oil firing that small a gallonage. Carlin & Beckett make great burners in that size range. Both able to run lo-hi-lo. Remember the 4 oil of today is not the 4 oil of yesterday. Very iffy. Hope this helps ED N.Y.C.
