2 oil burners- 1 tigerloop
rob brown
rob brown Member Posts: 69
hi all. was wondering if anybody could point me to a recent thread about multiple burners on single tigerloop. thought i saved it but can not find it. came across one with 2-100 gal. bocks. each burning 3 gpm. been working fine for years but now if both are fired at same time, older one flames out. not sure if starved for fuel or pulling air. i think i scared the owner into replacing ust. due to age(30+).good riddance. tia. rob
  • Steve_35
    Steve_35 Member Posts: 545
    The info I have
    says one TL per burner.
  • rob brown
    loop
    thanks for the info pitman, i thought that was the case. hopefully the owner will replace the tank, making it a moot point. rob
