Local TV News Did Segment Mentioning Low Level CO Monitors
Mark Hunt
Member Posts: 4,908
You may not know who he is,(invented the low level monitor) but you should.
He is a passionate man. He's working to change the system.
A smart PHVAC pro would do well to get up to speed on this issue.
I highly recommend Jim Davis' class. It will blow your mind.
Ask Mark Eatherton.
Mark H
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=238&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Ask Mark Eatherton.
Mark H
Last night on WBZ-TV in the Boston area they did a segment on the news talking about CO monitors. Although they didn't get into all the issues known and talked about here regarding UL approved CO alarms, they did create some awareness that the standard alarms may not give enough protection. They actual showed a CO Experts monitor as an example of of this other type of monitor.
The story can be seen at:
http://wbztv.com/consumer/local_story_045150048.html
To say the least I was shocked (and pleased) this made it on the news.0
- 76 Pipe Deterioration
