oil pressure at 140 psi
Big Ed
About .8 gph /112k btuh .............. no I'am not running out to truck for a chart :)
oil at 140psi
Oil pump set up to run at 140psi with .65 / 60oW.
as the instructions say. What is oil output now?0 -
.77gph
http://www.carlincombustion.com/OEM_SPEC/oemgd.pdf
Go down to page 32 and print it out. It'll come in handy later on.
Michael0 -
Hago web visit.
Hago said that the spray pattern will become wider.
the oil output must go up sum. Yes to .8 gph sounds good. thank you. Big Ed.
Big Ed ?
.03gph dif. Do do sports scores?0 -
about
and Big Ed you did say about!0 -
There is a formula do do this exact.
Divide the new pressure by the old pressure. 140 divided by 100 = 1.4 Take the square root of 1.4 = 1.183.
Multiply 1.183 X .65 = .769 gph.(new capacity)
This is gph not BTU's. the actual BTU's of the fuel could be plus or minus 10%0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
- 79 Pipe Deterioration
- 396 Solar
