Tiny boiler
adambuild
Member Posts: 422
Any ideas? Saw a water heater at a client's house today that's feeding baseboard. Total butcher job! What a disaster! We were there the whole day installing a gas line for a new cooktop in the kitchen. The entire time (6 hours) we were there, the B&G LR100 never shut off! Talk about "pumping away!" Tons of air noise! What a waste of fuel! I bet the client doesn't even know to shut it down when the weather gets warm outside. I did a heat loss calc and came up with a load of 26000btu/hr and would like to propose an inexpensive and efficient replacement. Any ideas?
Thanks in advance, Adam
Question....
How do they make their hot water? This will give a bit better insight. Chris0 -
Plumber's nightmare!
Majority of home is scorched air, basemboard as described earlier in 3 rooms, dhw by way of 50 gallon water heater.0 -
BTW..............
Load went up to 30,033btu/hr as a result of client requesting 2 basement rooms be added to project.0 -
Check out Slantfin
I think they have some little gas fired models
Boilerpro0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
