steam heat radiator control
I have a one-pipe steam heating system with a radiator in each of seven rooms. There are times I do not need heat in some of the rooms, so I close the supply valves to the radiators in those rooms and sometimes some of the other rooms get too warm, so I close the supply valves to their radiators and re-open them when they cool down. What is the best way to install automatic temperature controls in each radiator so I can easily select and maintain the desired temperature in each room as my requirements change? Are there specific mfrs and devices I should look into?
  • Sizzlaw
    Sizzlaw Posts: 11
  • ed wallace
    ed wallace Posts: 1,612
    steam rafdiators
    you need trv's those are thermostatic radiator valves the 3 companies i can think of are Danfoss,honeywell and Tunsall any good heating guy can get them for you or try a heating supply, supply house
