radiator
Bruce_17
Member Posts: 7
I've checked my EDR and cannot find this radiator. It may be that I have just missed it. If anyone can tell me what it is and what its rating is it would be most appreciated. Thanks. Wizzy
It's not in E.D.R.
I thought it might have been a "Fantom", made by American Radiator Co, but the Fantom was only a wall-hung unit. It was, however, a flue-type solid-front radiator like yours- if you can post its height (minus the legs) width and depth, we might be able to get a close approximation.
Check around where the pipes connect to the radiator, you might find a name there.
Is that the only rad of this type on your Vapor system?
it is the only one. No name on the radiator. I checked all over it. Also don't think it has been painted anough to cover any stamp. I didn't think that I saw it EDR. Must tell Dan that it should be "almost" EDR! Thanks for any help. Wiz0 -
Will have to get the dimensions tomorrow. Thanks. Wiz0 -
Get the dimensions
as requested above and I'll see what I can do.
The dimensions are 3" deep, 27" high and 57" wide. thanks. Wiz0 -
Can't find the exact match
but it should be in the neighborhood of 52 square feet.
- 87K THE MAIN WALL
- 114 Chimneys & Flues
- 106 Geothermal
- 982 Plumbing
- 388 Solar
