steam
Dan_29
Dan_29 Member Posts: 111
Hopefully your finished basement is insulated and has thermo windows (insulation is a lot cheaper than installing a bigger boiler).It would be good if your current boiler is large enough to heat the basement and your upstairs living area without any other changes.
Dan
PS: Make sure you have carbon monoxide detectors in the finished basement.
  • ed_44
    ed_44 Member Posts: 2
    basement
    My basement is finished. I want to leave the mains uninsulated to give heat to the basement.
    How can I do this and still deliver the best steam to the house?
  • bob young
    bob young Member Posts: 2,177
    aux. system
    insulate the steam mains and install a baseboard loop off the condensate. controlled temperature. comfort & economical.
