Grundfos 15-10F
van_9
van_9 Member Posts: 2
I was just on the Grundfos website and these are really low flow, low head pumps. On the 10 loop radiant job you mentioned, how do they move any water? Website shows them as 25 W.
  • Uni R_3
    Uni R_3 Member Posts: 299
    Grundfos 15-10F - Iron bodied...
    Do these actually exist? I've seen them referenced in some of the Grundfos literature but try and find one!
    The much much more expensive bronze 15-10B is easy to find but ideally I'd like to find an 15-10F in a flanged model.
  • Dave_4
    Dave_4 Member Posts: 1,404
    15-10F
    Yes, they do exist!
    I just installed 6 of them; 3 for injection and 3 for my radiant loops.
    Nobody has them in stock and they ship direct from the factory. Expect about 2 weeks to receive them. I don't know why they aren't more popular given all the radiant installs.
    I have one circulating a manifold with (10) 5/16 hePex loops (180-200' foot lengths). Works great!
    Tim
  • Uni R_3
    Excellent!
    Thanks Tim, did they have flanges?
    Also, do you recall if they are 25 or 33watts?
  • Dave_4
    Flanges
    Flanges would be either the up15-10F or up15-10FR
  • Tim P._2
    Tim P._2 Member Posts: 47
    Yes, the 10F has flanges (F= flanges, FR= rotated flanges).
    Off the top of my head, I believe they are 40w. I will check and get back to you.
  • Uni R_3
    No need Tim - Many Thanks
    Thanks Tim. I was never sure whether F meant flange or Fe(iron) because the B is bronze.
    Anyway, I got a SKU from Grundfos so I'm set...
  • Dave_4
    I used the Wirsbo ADS to design the system. The flow and head loss for the quicktrak system is within the parameters of the pump.
    I also am using the same pump for 1/2 hePex with radiant track (also 10 loops 250+- lengths) and my basement slab (also 1/2 hepex).
    I put a lot of faith in the ADS program, as the local plumbers I know all go by rule-of-thumb, "what we usually do" and "we never used a pump that small".
    When I bought my Biasi 3-section, I was told "we never sold a boiler this small". WADS says 32k required and the B-10 is at 67k.
    I was skeptical, but everything is working great. Just don't leave the front door open on the coldest day of the winter or it'll be a while before the room gets back up to temp :)
    WADS saved me a lot of headaches. Free to try and at $99 to buy is a steal. I highly recommend.
    Just curious as to what people are calculating the head loss is in their radiant systems?
    Tim
  • Uni R_3
    Got price on 15-10F today... something is bizarre!
    Why on earth would one of these cost almost double the price of a UP 15-58FC? I could see if it were bronze or stainless...
  • ALH_4
    ALH_4 Member Posts: 1,790
    numbers
    I bet Grundfos sells 500 UP15-58FC's for every UP15-10F they sell.
    Maybe a 15-58 on low would work ok for 20W extra?
    We all become slaves to misapplied zone pumps. I wonder if this is part of the reason Grundfos introduced the UP15-58FC which is significantly less expensive than the UPS15-42F. It might actually get people to try a lower curve.
  • Uni R_3
    Very true Andrew
    Yet I'm sure these 'lil guys would be far better choices for many of those circuits we see on the wall'o pumps shots here.
    Oh well... I tried.
  • Dave_4
    In my case, the 15-10F was $4 more than the 15-58FC, both being significantly less than $100.
    Considering the long circulation times, the $4 was well worth the energy savings.
    Tim
  • Tim P._2
    The pumps are indeed labeled 25w.
    Tim
