Buthead Buderous
ScottMP
ScottMP Posts: 5,882
you live but any chance of lightning in your area ? I have lost two to lighting.
You could also have a bad board, things happen.
If your not happy, call Buderus. I have found them to be a very helpfull company.
Scott
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=237&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Dave F_3
    Dave F_3 Posts: 4
    Buthead Buderous
    I have a Buderous G215 with a HS2105 control . After a few days the screen on the 2105 goes blank and the boiler is inoperable . It is almopst as if the boiler is running off a battery , and the battery si goping dead . After a few days of manual operation , it will work alright . A company rep has looked at it , and found nothing . I felt it was a grounding issue , drove 6 foot copper rod into the ground and used that . It still acts up . Please help . Thanks Dave
  • dead buderus
    i've seen battery die and boiler runs fine but program is lost. sounds like a bad ecomatic. who was rep? factory guy onsite or dealer/installer?
  • Have you talked to the guys at Buderus about this?
    I cannot see them not wanting to look after you. Them are some very professional stand out people!
  • Dave F_3
    Dave F_3 Posts: 4
    Buthead Buderous
    This is a retrofit . As far as I know it was a factory rep the customer had come out . Do you have a contact person other than the 800 number ? Where in Vermont are you ? Any Help would help Thanks Dave
