Steam Boiler - water leaving the boiler, going up the main
John_119
We have a steam boiler that is pushing water up the main when on a call for heat.This is a existing boiler ( 8 yrs.); it also has a hw loop for another zone. This zone is not calling when hh lose's water,
Suspect a blocked return! Any idea's ?
steamer trouble
If water is rising in the main, it can be due to a blocked return, or more likely improper near boiler piping. If the riser out of the boiler is not properly sized, or the header not built correctly, or no header at all, this could lead to your problems. What are the symptoms? How do you know water is rising in the main?
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
- 79 Pipe Deterioration
- 396 Solar
