New house - oil or gas?
"Our oil customers have all seen savings as well, but
not nearly as much as our gas customers have. I can't
make a 1.00gph nozzle burn less than 1.00gph."
That's true but you can change nozzles. Usually underfiring an oil boiler will improve steady state and seasonal efficiency.
  • Boston
    Boston Posts: 71
    New Hosue - Massachusets, Oil or Gas?
    I'd like to know opinions on oil or gas for a new home in Boston area. I just got a 600.00 bill for March in my older, smaller house and thnking OIL HAS TO BE LESS.
    We are using Icocynene insualtion, but I still think natural gas has goten very expensive. I know they don't give heating oil away, let me know your thoughts.....
    I always like the convenience of natural gas.
  • Compare the cost per BTU
    and go with whichever is cheapest per BTU. Be sure to include all the little taxes and fees that drive up the price of gas- don't just use the advertised price per therm.
    Note that some manufacturers of oil-fired boilers approve the use of their gear with power gas conversion burners where others do not. Using such a boiler would let you switch fuels without replacing the boiler.
  • S Ebels
    S Ebels Posts: 2,322
    Here's a cost comparison
    It's from the Energy Information Agency or some such Government research office. It's written in Excel so you can input the cost of fuel per unit and the efficiency of the appliance and it will do the math and give you the net cost per million btu's purchased. Find out what the costs are for the fuels in your area and use the efficiency of the appliances you are considering. It'll give you a solid read on what's the best way to go right now.
    I would ad a number of "it depends" to this however. The fuel use for your home is largely composed of heat and domestic hot water. There are other factors to consider if you want to use something other than electric for cooking and drying clothes. (I haven't seen a fuel oil fired range or dryer on the market if you get my drift) If you factor those in it will skew the balance toward gas if your electric KW rate is high.
    Also, there are some really awesome condensing gas boilers with modulating burners on the market these days. This is a feature not found on residential oil burners as yet and it makes a difference in overall system efficiency. The AFUE numbers don't do a good job of reflecting this feature.
    Enjoy the spreadsheet. It's listed as the attachment below.
  • ed wallace
    ed wallace Posts: 1,612
    new house in ma
    ok im from watertown ma and i can honestly say oil is cheaper then gas in ma. gas company makes its money on the extra charges like transmission charges what kind of heat are you going with hot air or hot water ?
  • Big Ed
    Big Ed Posts: 1,117
    Deregulation
    Oil was deregulated(thrown to wolfs down on Wall St.) in 1978 . Gas was deregulated in 1992.... That was the only time gas has been cheaper then oil. Then add the fact that gas is skimmed like cream off the the oil fields and heavy industry is forced to use it over coal for emmision standards. My bet would be with oil. A matter of fact I switch over to oil a few years back ...
  • Depends
    On BTU load, if you have a small btu laod look to a gas modcon but, if your getting to loads that can be matched with an oil boiler that would be my choise.
  • ed wallace
    gas vs oil
    remember that with gas you can direct vent and not bother the nieghbors but oil direct vent or power vent does give off an oder and will stain side of building
  • Boston
    Boston Posts: 71
    S -
    I can still bring in Natutal Gas for cooking and/or gryer, but use oil for heat. .. The dual fuel boiler would be intriguing, change for best options....
  • Constantin
    Constantin Posts: 3,796
    Agreed...
    However, if you choose to use B5 oil, then the odors virtually disappear. B5 has very little sulfur in it (~45PPM or less) and since I made the switch, the only residue I have left in the boiler is a very minute amount of brown dust.
    Since the availability of B5 is not widespread, I would always opt for a chimney install, if possible. It's tried, it's true, it's hard to screw up.
    I also went for oil 2 years ago when we renovated this structure. Given this years gas prices, I am very happy. Boston location also.
  • J.C.A._3
    J.C.A._3 Posts: 2,980
    How much can you afford?
    Like Steamhead, I like the choice. If your buying an oil boiler, make it something that can be converted in a price or pinch scurry.
    The only boiler that can and has been designed to do both right out of the box is the Viessman Vitola.
    The burners can also be mounted on the same bolts/points available with the boiler.
    A knockout on the burner cover is all that seperates the appearence between the two....but the burners are two seperate units, fitted in the same housing.(actually, they use alot of the same components but are adaptive to both fuels)
    When attending a class at the Viessman factory in R.I....I was told that they sell the boiler with both burners in a few situations. Apparently the saavy homeowner knew to buy it as such...and did. (smart....very smart!) Chris
  • S Ebels
    If you're using a boiler
    The Viessmann Vitola is just about the ultimate. The M1 Abrams tank of boilers if I say so myself.
    It can be had with gas or oil burners and if you ever wanted to switch from one fuel to another you can buy the appropriate burner, install it and presto, the same boiler is using a different fuel. This fall it will be available in condensing form also, allowing you to wring about every btu out of your fuel. (This requires a different flue set up) I have heard through the grapevine that modulating burners are also in the works for this unit. It's big, it's high mass, it's very heavy. The failure rate on it is .005 %, just about low enough that you could say they never break. The only drawback is expense but it will likely be the last boiler you ever buy as is can integrate with any type system be it radiant, cast iron rads, hydro air, baseboard, panel radiators solar or any combination of these. Viessmann keeps refining this sterling piece of equipment allowing it to remain at the state of the art even though the design is about 20 years old. Still nothing else like it on the market. It's what I have in my own home, running gas at present. It's pretty cheap here compared to you poor folks on the East coast. The fact that this boiler will work with anything is one of the main reasons I bought it. I think flexibility in fuel choice is going to be an issue of some prominence in the near future.
    Go here and check out the spec's for the Vitola 200. It's listed under gas and also oil fired boilers.
    http://www.viessmann-us.com/web/canada/ca_publish.nsf/Content/Produktprogramm_ca_english
  • Uhhh, Chris
    the Biasi and its private-label incarnations are also approved for and sold with power gas burners. We'll be installing at least one Columbia Solaia which is a rebadged 3-pass Biasi this summer, factory equipped with a Heatwise power gas burner.
    Why Columbia? Their local supplier is first-rate.
    Watch the Wall for pics.
  • House insulated now, Brian?
    Your $600 for March in a small house struck me. I am sure there are several factors but is your house insulated with Icynene now or is that coming up?
    If the house is now insulated, I have to think that the gas company is reading someone elses meter and calling it yours... happened to a co-worker of mine; billing him for a downstairs tenant who liked it warm...
    Curious.
    Brad
  • Boston
    Boston Posts: 71
    Brad:
    I say small, but its 3300 sq feet, plus a heated 2 car garage. It might not be all that well insualted, the new house will have the foam insualtion in the ceiling only. fiberglass in the walls.
    Sounds like it should be oil. Gas is out of hand. Constantin, sounds like you made the similar decision and went with oil - that is good enough for me!
  • KAG
    KAG Posts: 82
    Gas or oil which is better? 1st find a local contractor trained in both areas. One that is willing to discuss pros and cons of both. Discuss services requirments, this is probaly the most important discussion you can have. Many oil and gas companies will not services unless they supply the fuel. Next pay to have system designed for both fuels, should not be much of a difference. If the system is PROPERLY design cost diff will be minimal. Remember fuel cost could rise for both and designed properly today can save a lot tomorrow. If the system is over sized or improperly installed this will cost you more than which fuel is more cost effective.
  • Mark Hunt
    Mark Hunt Posts: 4,908
    Question
    When you drive your vehicle, do you floor it and use the brake to control your speed??? Or do you modulate the amount of gas you send to the engine according to what the driving conditions require?
    So it is with the heating plant in ANY structure. ALL are designed toward worst case scenario, or "design day load".
    9 times out of 10 the "design day" is grossly over-estimated and so follows the heating plant size. Grossly over-sized for 99.999% of the heating season and slightly too big for the rest.
    We were contracted to install a heating system for a 5,000 square foot building two years ago. The rest of the "pros" came to the table with boiler outputs in the hundreds of thousands. We installed a modulating boiler (Munchkin T-80) with a max output of 74,000 BTU's. Our system has never failed to heat the building to 70 degrees.
    The modulating boiler only eats what it needs on warmer days, non-modulating gas and oil units will eat like pigs each and every time they fire. Fixed-fire appliances do not care "what you need", they only care about "what THEY need".
    With PERFECT combustion, oil is said to produce 140,000 btu's per gallon. Well what if you only need 15,000 btu's??? The fixed-fire units still eat like "Larry The Cable Guy's" sister at a buffet. (Now that's funny!)
    You're building a new home that will be insulated better than most. What is the heat loss for your new home on "design day"??? What percentage of time will your home be at "design day"??? 10%?? 20%?? Maybe 5%....
    The rest of the time you will be over-sized and WASTING FUEL!!! That, sir, is a fact.
    If you still think oil is the way to go, fine. Then I would suggest this. Treat your oil burning system just like a wood boiler. Install a 1000 gallon thermal stroage tank and let your oil boiler work against that. THEN, just pull out what you ACTUALLY need. No different than burning wood. Burn it as hot as you can and yank every BTU you can from it. Store it and save it for later.
    Mark H
  • Mark
    You bring up very good points . For us it's been a return of the mild winter . I installed an indirect heater and rudimentary outdoor reset to my oil boiler in January . Last delivery of oil was Jan. 20 ( $2.06 gal ) , right now we're at 1/8 of a tank out of an initial 250 gallons . The delivery before last was early November ( $2.04 gal ) . Granted , I have a small house ( 1400 sq ft ) , but it's leaky as a sieve . Typical oil usage for us before the upgrade was around 900 gallons a year , even the milder winters ( give or take 100 gallons ) .
    I wonder how to go about figuring what kind of fuel usage a similar home as mine would have if there was modulating gas equipment installed in it ? Btu to btu fight , you think a modcon gas boiler would show a significant decrease in fuel usage compared to a triple pass oil boiler running on outdoor reset , ala MPO ? Or a low water content , cold start oiler like a System 2000 . Do you track gas usage in homes you've upgraded to modcons ?
  • And so is
    the Enery Kinetics System 2000 . Can be used with a power gas burner .
  • Mark Hunt
    Yes and no
    I don't track it, I get the info from the homeowner. They tell me what their gas bill said they used. That I keep tabs on.
    Our oil customers have all seen savings as well, but not nearly as much as our gas customers have. I can't make a 1.00gph nozzle burn less than 1.00gph.
    Might be able to soon though. Then we'll have something to brag about.
    Mark H
  • heatboy
    heatboy Posts: 1,468
    I agree.
    Without a doubt, the Vitola is almost the perfect boiler. I have them fired with both oil and gas. I said it before, I'm fond of the Vitodens, but I love the Vitola! I wish I never had to install anything else.
    hb
  • But .......
    what equipment did you use in your oil customer's homes ? Was outdoor reset used ? Indirects for hot water ? I can't imagine you and Darin installing anything that would use a coil :)
    I agree you can't make a 1 gallon nozzzle burn less than 1 gallon , but does that always translate to higher fuel bills to the customer compared to high efficiency gas ? I bet true numbers would be closer than we think if top of the line is used with either fuel choice .
  • Constantin
    Hmmm...
    I agree that the first step towards lower fuel bills is to optimize the heating system WRT the building. The boiler is but part of that equation, as are emitters, transport lines, etc.
    I would love to see some empirical comparisons between low-mass, modulating, condensing boilers and their non-condensing, high mass bretheren (think Vitola vs. Vitodens) assuming both are optimally sized. Some people I have met in the industry claim that the differences well installed systems are actually smaller than the real-life experience of the likes of Mike T in Swampeast or Brad White suggest.
    However, given how well those two know their heating systems, I tend to tip my hand in favor of real-life conditions vs. lab results and/or hypothesis'.
    For me, the choice of fuel is purely analytical. Both oil and gas will do a fine job of safely and reliably heating a home. Either can be had in a condensing package in the US, though only gas-fired units also offer modulation to date. So, I'd take a look at fuel price trends in your local area, compare the prices while accounting for efficiency differences and letting that determine the choice of fuel.
    Local conditions traditionally made oil a less expensive fuel to use in this area. Other parts of the country have different conditions, so there is a need to research locally.
