Text Size
DanHolohan
Member, Moderator, Administrator Posts: 16,682
Retired and loving it.
For Dan, Text size of posts??
Hi Dan,
New look is really nice. I have one question. The text in the posts is substantially smaller than it used to be.
I went into my computer options and made text largest, and it did make all of the text on my screen larger, except the text in the individual posts. That is still small.
Is there anything that I can do to make that text larger?
Is it only here on my computer, or do others have the same?
These old eyes are not what they used to be.
Thanks, in advance
Ed Carey0 -
How's this, Ed?
Better?Retired and loving it.0 -
YES
Did not realize how small till the change thanks dan!
Terry0 -
They didn't change the point size,
just the font. I'm glad you're happy.Retired and loving it.0 -
I think the "new look" is great! Easier to read somehow.
Thanks, Dan,
Ed0 -
Much Better
Yes Dan,
Much better
Thanks,
Ed Carey0 -
whoooaa!
Squinting to read small font and ballooned to x-large fonts and back to small, my eyes are getting a workout! Keep up the good work, knowliy one size doesn't fit all..0 -
Looks really nice Dan!
Dan Dan he's our man!0 -
I still
miss the ability to make the text much larger.
The rest is excellant.0 -
you can go to your browser's preferences and go to
fonts, where you hopefully can change the size, and also change to 'sans serif' which makes very clear reading. Might have other font choices as well. Also when looking at a wall thread on my Mac by holding the apple key and then hitting the 'plus' sign the font will get bigger each time I do that. (That stays that way until I quit the Wall.)
good luck,
David0 -
thanks, David
Thanks for the tips, however, I'm using the sidekick to gain all my vauable informations from the fellow wallies...0 -
Just enlarges the response listings, not the actual responses for me??0 -
In Options
what font size do you have checked?Retired and loving it.0 -
Dan...what was the old font size and points....was it courier 10....?0 -
I'm not even sure.
I did ask Invision when I called to have it bumped up, and they said that the point size hadn't changed.Retired and loving it.0
